Lift Options ?
Old Mar 1, 2012 | 12:13 AM
Hylander7's Avatar
Hylander7
Default Lift Options ?
So I need to lift my truck a Tad, I figure 2" - 2.5"
With just 2.5" I shouldn't have to change my Trac-bar, Control arms or Pitman arm, correct ?
I already need new shocks, so that is not a concern.
Was thinking of Coils instead of spacers
Anyone use these guys ?
These are $130 shipped
http://www.customsuspension.com/dodge_leveling_kits.php
Other options are:
Rough Country makes 2" Coils
Superlift makes 2.5" Coils
I also have looked everywhere for used 2500 coils, but there are none
to be found, new ones are $160
I would like to retain a factory ride, not harsh like Rancho.
Whats your thoughts ?
Old Mar 1, 2012 | 12:41 AM
P1NKST@FF's Avatar
P1NKST@FF
I love my spacer, truck actually rode better and kept stock shocks. Did a add a leaf in the back wick I think lowered my ability to carry stuff but other than that I only have good things to say. I know you said you don't want a spacer but why?
Old Mar 1, 2012 | 12:48 AM
Hylander7's Avatar
Hylander7
Two reasons:
1: I think my factory coils are tired
2: If I go 2" -2.5" coils, Later if I want more lift I can add the spacers
Old Mar 1, 2012 | 12:57 AM
P1NKST@FF's Avatar
P1NKST@FF
My truck has 270k and only rides crappy cuz its on it's second tired set of shocks and nm roads suck. Most stuff that I have read advise against combining the spacers with any other lift, I would do the space again because it was $80 and 45 minutes of work including us trying 3 different spring compressors $.02
Old Mar 2, 2012 | 12:35 AM
Hylander7's Avatar
Hylander7
Anyone else ?
Old Mar 4, 2012 | 04:53 PM
Hylander7's Avatar
Hylander7
I'm measuring ride height as the height of the springs installed.
I just measured mine on the truck and they are 12" and the spring diameter is .760
Also, Measurements from axle center to fender is:
Front: 23"
Rear: 25"
Does anyone know the measurements with 2500 5.9 gas springs installed ?
The spring specs say 16" ride height, that would give me 4" lift
But I have read that people are getting 2" lift
A Little confused here
Old Mar 4, 2012 | 05:08 PM
ryan0714's Avatar
ryan0714
just my 2 cents cuz i have done it all and seen it after different things. if ur gonna go coils, go with 2" cuz ur old coils are prob. saggin some, so when u put new ones on u might actually get like 2.5" until they set in some.
Old Mar 4, 2012 | 10:51 PM
Wombat Ranger's Avatar
Wombat Ranger
All I can say is my 2500 v8 sits about as high up front (factory suspension) as a 2" leveled 1500. I have the 8800 GVWR with a 5.9, nv4500, reg cab long bed, so its a lightweight heavy duty. I weigh in at about 5200 lbs. Hope that helps.
P.S. Those are 33's on my '95 in my sig picture, if that gives you any idea.
Old Mar 7, 2012 | 02:01 AM
Hylander7's Avatar
Hylander7
OK;
I think I am going to order a set of 2500 gasser springs 8800GVW
Any reason not to ?
Anyone running these ?
Old Mar 7, 2012 | 06:47 PM
Wombat Ranger
Didn't think of this before, but a small amount of my height difference is probably due to the fact that I have a larger axle up front. The thicker diameter axle tube must naturally push the hub farther from the bottom of the spring.
Just a thought to keep in consideration.
Also, I would think that lift springs designed for a 1500 should ride nicer than 3/4 ton springs.
