P01281 / Truck too cold
Old Mar 2, 2012 | 08:30 AM
i mow grass's Avatar
i mow grass
Default P01281 / Truck too cold
After searching through and reading previous threads on this I just wanted to get some clarification.
I recently finished up my plenum, tune up, etc., however I also installed a 180* Thermostat without really reading much into the topic. The truck started throwing the 1281 on me twice in the past 2 days. Would my best bet be to go back to a stock 195? Or do I have some other underlying issue that I am missing here?
Thanks
Old Mar 2, 2012 | 08:36 AM
Nope, no other issues. If you are running the factory tune, go back to the 195 degree stat.
Old Mar 2, 2012 | 09:31 AM
EndIsNear's Avatar
EndIsNear
Mine did the same thing with a 180* stat, then went back to 195*, and it still threw the code. Found out my Coolant Temperature Sensor was bad. Replaced it, stayed with 195* stat with Superchips, no problems whatsoever
