Fastman t body 50mm
Old Mar 5, 2012 | 10:38 PM
Augiedoggy's Avatar
Augiedoggy
Originally Posted by ramthis9501
Starts at 50 and goes down to 47 below the blades
yup....just stick your finger down the hole you'll feel the opening is bigger towards where the plates mount... all fastman and the others do for a 50mm is remove the taper at the top cut off the airhorns and polish things up...mainly
Old Mar 5, 2012 | 10:40 PM
ekaplan's Avatar
ekaplan
I have a 52mm and just found out today that the idle needs to be bumped up a bit. I never thought of it. But i wouldn't get enough air at start, basically choking it, run pretty rough then level out in about a min. Somethin to think about if you have any problems.
Old Mar 5, 2012 | 10:45 PM
Augiedoggy's Avatar
Augiedoggy
52mm is a totally different ballgame...only benificial if you have a 360 with mods to help it breath better like a better flowing exhaust and heads or at least 1.7 rockers.. to get the air out as fast as it gets in.... its not recommended for stock 360's or mild 318's...you actually lose power throught the low and mid range..with the latter.
Old Mar 5, 2012 | 10:49 PM
ekaplan's Avatar
ekaplan
I can see that. I just wanted to see the difference myself. A lot of ppl were recommending 52. Unfortunately it went on with new motor so have nothin to compare to lol
Old Mar 5, 2012 | 10:55 PM
iwhitne's Avatar
iwhitne
I loved mine! didn't have time to pull it before I traded in for my cummins
Augiedoggy's Avatar
Augiedoggy
you have a very close setup to mine..
Old Mar 5, 2012 | 11:03 PM
ramthis9501's Avatar
ramthis9501
Mine idles a little rough when its cold... think I should bump the idle up a bit with my tuner? It idles around 900 right now.
Old Mar 5, 2012 | 11:05 PM
Augiedoggy's Avatar
Augiedoggy
900 is higher than stock I believe?
Old Mar 5, 2012 | 11:07 PM
ramthis9501
Thats when its cold in the morning... It idles around 650-700 when its warmed up. No rough idle then
Old Mar 6, 2012 | 12:18 AM
ekaplan's Avatar
ekaplan
Mine sat at 700 rpm on the gauge but 670 on the scanner. Bumped it up and cured my rough idle. Yours sounds opposite of mine. Mine was fine when cold because of the higher idle.
