Adding factory keyless entry?
Old Mar 6, 2012 | 06:02 PM
Cavalry's Avatar
Cavalry
Default Adding factory keyless entry?
I have a 99 that is loaded except keyless entry. I happened across a junk 98 with keyless entry. I know the central timer module controls the keyless entry. Is it a simple swap or easier to go aftermarket?
Old Mar 6, 2012 | 11:34 PM
Jason_Dodge's Avatar
Jason_Dodge
Funny enough, i was about to start a thread about the system i got in my truck. It's factory. But some things don't work right. Like the alarm and such. I'd go aftermarket.
Old Mar 7, 2012 | 05:50 AM
Novarider's Avatar
Novarider
Go to the dodge dealer and see if you have the correct key fob (the keyless entry remote) if so they can program it for you.
Old Mar 7, 2012 | 08:03 AM
redneck_ram's Avatar
redneck_ram
i have a ctm id be willing to sell for cheap, and you need the whole dash harness too, of course you will need the remotes also.
Old Mar 7, 2012 | 10:46 AM
Cavalry's Avatar
Cavalry
My 99 was not equipped with the correct CTM for keyless entry
The junk 98 has key fobs with it, so I would not need them reprogrammed.
Old Mar 8, 2012 | 08:06 AM
Novarider's Avatar
Novarider
I miss read it. I thought you just needed the key fob.
