shifter issue
Old Mar 8, 2012 | 03:46 PM
ferd15's Avatar
ferd15
Default shifter issue
To put it into drive it has to be in neutral. Neutral is reverse and rev is close to park. 1st gear is 2nd. And the 2nd is when u put it in drive. Also. It dosent go into the 1 on the colum. But 1st gear is 2. On the colum. Hope it makes sense any ideas? Everythings basicly pushed up. And it dosrnt like to stay in a certain gear.
Old Mar 8, 2012 | 03:48 PM
ferd15's Avatar
ferd15
Also to drive it needs to be in neutral on the dash. But its rly drive. But as im goin i feel it slip in amd out. This only happens sometimes most of the tome it stays in drive
Old Mar 8, 2012 | 05:13 PM
ferd15's Avatar
ferd15
Also it only starts in neutral
Old Mar 9, 2012 | 02:29 PM
zman17's Avatar
zman17
Retired Moderator - RIP
Get a Haynes and download the free FSM from the FAQ/DIY section , and check and adjust the linkage.
Old Mar 12, 2012 | 12:41 AM
ferd15's Avatar
ferd15
i did.. looked it up and messed with the linage and everything didnt really fix anything. still starts in neutral and sometimes it will start in park.
Old Mar 12, 2012 | 03:48 PM
zman17's Avatar
zman17
If you remove the knee panel, you will see a plastic adjusting screw with a thin metal cable. You can try adjusting that.
