Intake full of oil
Old Mar 8, 2012 | 08:41 PM
kal's Avatar
kal
Default Intake full of oil
I had just replaced 2 cracked cylinder heads on my Ram 5.2l and got it started up today. It ran for about 5 minutes (the temp gauge didn't even move yet) before it started smoking real bad. I shut it off and looked for the problem and found a lot of oil sitting in the bottom of the intake. I had replaced the intake and plenum gaskets and even put rtv around the plenum after it was installed on the intake. It is the steel plenum because I can't afford the aluminum one right now but I figured it would last at least a few years. I did use a torque wrench on the bolts so I don't see why it would be leaking so bad. Is there any other causes for large quantities of oil in the intake? Thanks for the help.
Old Mar 8, 2012 | 09:00 PM
Could be a bad PCV valve. Also, did you re-use the plenum bolts? The primary reason for failure of that gasket is because the bolts are too long......
Old Mar 8, 2012 | 09:42 PM
kal's Avatar
kal
Thanks for the quick reply. I just checked the pcv valve and there was no trace of it sucking up oil. I did reuse the bolts, they didn't seem too long when I put them on and I torqued them to 84 inch pounds in the 3 steps the haynes book said to. I guess I'll have to take the intake off again this weekend. How long are the bolts supposed to be. Could I just put some washers on them if that is the problem?
Old Mar 8, 2012 | 09:56 PM
Just putting some washers on them would probably work just fine. Be sure to use some blue lok-tite on 'em. You do NOT want them fellers coming loose, and dropping into the engine..... No fun at all. And makes some really rude noises......
Old Mar 9, 2012 | 02:36 PM
zman17's Avatar
zman17
Retired Moderator - RIP
You can also grind the nipples off the end of the bolts(that's what I would do). Or just buy new shorter ones. Just me I'm sure, but I'd rather not use washers. Just something else to go in the motor if a bolt should come out. And get a felpro gasket and do NOT use RTV on it. Only place for rtv is in the four corners where the rubber gaskets meet the head, and a very , very thin layer around the water ports.
