Is a wheel bearing easy to replace?
Old Mar 10, 2012 | 05:30 PM
grox's Avatar
grox
Originally Posted by dhvaughan
true - new rotors also come with new bearing races already pressed in, so you don't even need a hammer and chisel and socket to beat in a new race....
Depends on the rotors. I've only replaced mine once and they came bearing-free. And the chisel would be for removal.
I keep my eyes open on Rockauto, every few months they'll have rotors on clearance at a huge discount. Mine had a real tendency to warp before I replaced the ceramic pads the PO had put on with stock semi-metallic.
Old Mar 10, 2012 | 09:06 PM
Obiejuankinobie's Avatar
Obiejuankinobie
I have a 2001 2wd and need the drivers front replaced. When I replaced the rotors & pads I thought where the heck is the bearing behind the castle nut??? Holy smokes its the hub that needs replacing. So looking for a hub and probably will need a air impact hammer or does the hub come off with just removing the 185 ft Ilb tightened nut. Man I am one payment left on my truck note and it's crying out for everything...geez
