Reverrse light wire under dash?
Old Mar 18, 2012 | 06:27 AM
Prototype's Avatar
Prototype
Default Reverrse light wire under dash?
I bought a backup camera off amazon and hooked it to my radio, the radio uses a positive trigger to switch to the input for it. Is there a wire under the dash that I can tap that comes hot when I put the gearshift in reverse? I'd rather not tap it at the trans and run a wire back to the cab.
Old Mar 18, 2012 | 08:23 AM
redneck_ram's Avatar
redneck_ram
grab the 2001 service manual from the faq section, and go from there. granted your rig is a 98, but the 01 manual should do the trick.
Old Mar 18, 2012 | 09:13 AM
dhvaughan's Avatar
dhvaughan
i doubt it.
there is a power wire and fuse for backup lights in the end of the dash, but the switch that turns it on/off is on the drivers side of the trans, at the neutral/safety switch. its the electrical connector at the linkage. it has 2 or 3 wires and probably powers one wire in neutral and the other in reverse.
Old Mar 18, 2012 | 12:48 PM
gdstock's Avatar
gdstock
Service manual will show where you can pick up that wire.
Old Mar 18, 2012 | 01:34 PM
zman17's Avatar
zman17
Retired Moderator - RIP
Why's that? Is that too easy?
Old Mar 18, 2012 | 02:11 PM
Yes. I believe it is necessary to run a wire from one of the reverse light sockets, back to the front of the truck.
Old Mar 18, 2012 | 02:22 PM
Prototype's Avatar
Prototype
Originally Posted by gdstock
Service manual will show where you cann pick up that wire.
I actually got both the 96 and 01 manuals, truth be told though, I can't read the wiring diagrams for &%*&.
Originally Posted by dhvaughan
i doubt it.
I know that the wire is at the NSS, I just didn't want to run a new wire down to it to tap it, I was hoping I could tap it under the dash.
Too easy, no, just annoying to find another grommet to poke the wire through. lol
Old Mar 18, 2012 | 02:33 PM
gdstock's Avatar
gdstock
There is a grommet near the brake pedal that should have room to spare. I used it to run several wires through when I installed trnas temp sensor, vacuum gauge hose, and other things as well. I believe it is to the left as you look under dash. Removing knee panel will make it easier. It would be a good time to check to see if you have any chaffing wires on the steering column as well.
Old Mar 18, 2012 | 02:50 PM
Prototype's Avatar
Prototype
Alright, I can have a look there once it stops raining, I do know I don't have any chaffing wires on the column because I just recently put in a keyless entry / remote starter.
