Can anyone play "find that squeak?"
Old 03-20-2012, 08:07 AM
Sheriff420's Avatar
Sheriff420
Sheriff420 is offline
I have a squeak that I can't track down too. Mine is more of a "whoop whoop whoop" noise. The noise is identical to the noise you hear when a pigeon takes off. It only does it when the truck is warmed up and moving at slow speed but sometimes it will continue to do it for a couple seconds after the truck has stopped.
My solution to the issue is a good sound system in the truck.
Old 03-20-2012, 12:39 PM
all4mud's Avatar
all4mud
all4mud is offline
i had the same issue for a while. the top of the gas tank rubs on the pinch weld at the bottom of the cab between the bed and cab. wasn't enough to wear a hole or damage it but just enough to make a plastic on metal squeek. try spraying some wd40 down there.
Quick Reply: Can anyone play "find that squeak?"
