Massive Fuel Leak
Old Mar 19, 2012 | 02:23 PM
gdstock's Avatar
gdstock
Wow. With that much leaking you are fortuneate that nothing caught on fire. Glad you and the family made it home safely! Good luck getting the line in short order. Can't they overnight that thing?
Old Mar 19, 2012 | 03:28 PM
Gary-L's Avatar
Gary-L
Veteran: Navy
Don't let this happen to you:
Old Mar 19, 2012 | 03:44 PM
scottas's Avatar
scottas
I disconnected the battery to avoid my truck being an actual charcoal gray instead of being painted that color.
However, the upper quick disconnect (the one at the fuel rail) came off with little argument. The lower one (attached to the hard line) won't even budge. I am using a 3/8" and it goes in, however I can't push the flex line in towards the tool.
Any ideas fellas? You guys have been more than helpful. Looks like a jy about 15 minutes away might have what I am looking for, but I want to get this one off first.
Old Mar 19, 2012 | 03:50 PM
Gary-L's Avatar
Gary-L
Veteran: Navy
Old Mar 19, 2012 | 05:25 PM
scottas's Avatar
scottas
Got it off with some PB Blaster and some vice grips. Come to find out the piece isn't all flexline, it has hard line with flexline at each end.
There wasn't any holes in the braided line (that would require a lot of pressure) but it seems the crimp on the bottom side of the hard line has failed. Here's to hoping this jy has what I need.
Old Mar 19, 2012 | 06:12 PM
zman17's Avatar
zman17
Retired Moderator - RIP
Yea, thats no mystery. The only place thats flex is about a foot starting at the fuel rail. Then hard line to the second half connector that I was talking about.
Old Mar 19, 2012 | 08:02 PM
scottas's Avatar
scottas
Sorry zman17, I didn't understand what you meant without looking at one. I just picked up a jy line (from frame hard line to fuel rail) for $15. I will probably spray some carb/choke cleaner down it, clean it up some and put it in my truck.
Thanks again guys for the help.
Old Mar 19, 2012 | 10:09 PM
scottas's Avatar
scottas
I got the jy fuel line installed. I paid $15 for the whole of it (from frame-mounted hard line up to the fuel rail). I wasn't able to get the hard line portion clipped back into its intended place, but I am confident it is out of harms way. When I replace the cap and rotor I will try to get the fuel line properly routed though.
Thanks for sharing your knowledge and experience with me.
Old Mar 19, 2012 | 10:14 PM
It's a truck again? Awesome. Glad ya got it fixed.
Old Mar 19, 2012 | 10:16 PM
gdstock's Avatar
gdstock
Glad you got it fixed....a trip like that costs like heck. Glad no one was hurt. Make sure to secure that hard line so vibtation doesn't break it. $15 wasn't bad at all. Wonder waht the dealer would have charged?
