no park lights, voltage at ground?
I ran through some water holes a couple of weeks ago, and a few days later lost my park lights. I found that if I disconnect the two plugs behind the driver front wheel for the rear end, the fronts would work. I cleaned the connector, and plugged it back and the fuse blew again. I have been fiddling with it for a few hours now, and no luck. The weird thing is that I show 12.5 volts to BOTH of the contacts for the park lights in the fuse box. When I throw the park switch, though, it drops to around 1.5 volts on one leg. Odd, huh? I started checking other fuses, and I have 1.3 volts on one leg of the maxi-fuse for the trailer lights. Can some one recommend something? I need to get her inspected in a few weeks....
Sounds like you have a trailer harness.... they sucked from the factory. The connections would get cruddy, and decay, and give all sorts of trouble. I would look where the trailer harness meets the rear harness first.
