Ignition switch problem
Old Mar 22, 2012 | 11:45 AM
Kentucky Fried Redneck's Avatar
Default Ignition switch problem
Well with one plenum fix down and one to go I decided to take a break and tackle this other issue. When I start the truck, if I don't turn the ignition switch back just a hair my Air Bag and ABS lights stay on. Also I just recently discovered that once in a while (done it twice and can't replicate it for anything) when I turn the key off, if I go back to far (like to the accessory setting) the starter will engage but not turn over the engine, just the starter whining away. Before I drop $100 on a new ignition cylinder and tear into the steering colum, I want to make sure that's the problem.
Aside from that I haven't noticed any other electrical issues. Details on the truck are in sig - bottom truck
Old Mar 22, 2012 | 04:27 PM
zman17's Avatar
zman17
Retired Moderator - RIP
Does sound like ignition switch. $55 at rock auto(plus you can use the discount code from the general discussion section) and $65 at advance.
Plus, you'll want to pull the covers off the column anyway to check for damaged wires regardless. If you have tilt wheel, it's fairly common for wires to get damaged .
