O/D switch please help
Old Mar 23, 2012 | 09:49 AM
01PurpleHaze's Avatar
01PurpleHaze
Default O/D switch please help
how do i diconnect my overdrive switch?? the end of my shifter is broke off which the switch was on the end of it and it keeps shorting the wires out and turning off my O/D and my trans over heats, i just want to unplug the switch to get rid of the problem
Old Mar 23, 2012 | 10:16 AM
Augiedoggy's Avatar
Augiedoggy
you tranny shouldnt overheat with it off? if anything it runs hotter in overdrive... and if it is overheating it turns off the overdrive to attempt to cool off.... so if your od light keeps coming on it may not be a short but rather your transmission is on its way out... this happens when the torgue converter starts to fail...
the od light also turns on when someone doesnt pay attention to the owners manual and attempts to tow in overdrive.... it overheats the tranny , the light comes on and od turns off... eventually this burns out the transmission fliud and transmission.
Old Mar 23, 2012 | 10:31 AM
01PurpleHaze
well the trans temp light comes on like 20 seconds after the O/D light does, and ive had 3 transmissions and 3 torque converters and theyve all done the same, any suggestions?
Old Mar 23, 2012 | 10:36 AM
PapaG's Avatar
PapaG
So it's done this with 3 different trans and torque converters in it? Am I understanding that right? Have you checked to see if your trans cooler is clogged up? Have you done the check valve delete? Sounds like your lines may be clogged up and not cooling the trans properly...
Old Mar 23, 2012 | 10:39 AM
Augiedoggy's Avatar
Augiedoggy
So that means your transmission is overheating... It turns the od of right about the time or slightly before) the computer tells you its overheated... (when the light comes on the OD turns off just to be clear)
To me that says somethings wrong with your transmission... have you checked the fluid in neutral while the engine is running?
I'd say something else may be wrong if you burned up three transmissions... maybe the PCM is messed up?
are you running large tires without the right gearing?35" or biger can overheat things and burn up transmissions quick..
just saw papaG's comment...good suggestion.
Old Mar 23, 2012 | 10:49 AM
01PurpleHaze
i have 33'' with i think its 3.55 gears, and yes ive installed 3 transmissions and 3 torque converters and ive had the same problem, ill hafta check the lines and cooler and see if that changes anything thanks for the information guys
Old Mar 23, 2012 | 11:06 AM
If you still have the check valve in the line going to the radiator, get rid of it.
Old Mar 23, 2012 | 11:23 AM
01PurpleHaze
where would i look for that that at? just follow the line from trans to the radiator???
Old Mar 23, 2012 | 11:26 AM
From the lower fitting on the radiator, a soft line hooks on, and heads back 8 inches or so, to a couple metal fittings, that connect to the hard line via a flare nut, Between the soft line, and the flare nut, is the check valve. You can just replace that section with some hose, and a couple clamps, you can drill out the check ball in the valve, or, you can make up a new hose with the right fittings (quick connect on one end, flare fitting on the other.) for around 30 bucks or so. I just used a piece of trans hose, and a couple clamps. Less than 5 bucks.
Old Mar 23, 2012 | 11:29 AM
01PurpleHaze
ok thanks ill have to look into that aswell thanks
