Sagging leaf springs
Old Mar 23, 2012 | 05:37 PM
Verate's Avatar
Verate
Default Sagging leaf springs
2002 ram 1500 qc 4x4, My poor truck's leaf springs are about shot. The truck sits about level lol but they sag to the point they raise up over the axle like a slight w shape. Anyways i was curious where a good place to get new leaf packs was or to get them re-arched. Im located in hinesville Ga aka Ft Stewart. Thanks
Old Mar 23, 2012 | 05:59 PM
Lone136's Avatar
Lone136
I got mine from 4wheeldrive.com, but mine are lift springs. If your going bad stock any parts store should be able to order them for you. If you are going to change them now would be a good time to start putting some PB Blaster on the U-bolts
Old Mar 23, 2012 | 08:07 PM
dhvaughan's Avatar
dhvaughan
don't have the old one's re-arched. its expensive and they will always sag back and end up being a big waste of money.
my links might be for a 94-01 model, but check these places.
http://stengelbros.com/
http://www.sdtrucksprings.com/leaf-s...ram-1500-94-01
http://www.generalspringkc.com/
http://www.autoandtrucksprings.com/p...g-1094-36.html
http://www.huskyspring.com/Aftermark...--_p_3756.html
http://www.autopartswarehouse.com/de...T341339HD.html
Old Mar 23, 2012 | 09:02 PM
Verate's Avatar
Verate
Thank you for the links, i may try to pick up a set from the junkyard. Lol atleast with the savings i could put in an add a leaf. That and the rear end needs work, so new pinion seal takes priority. A bit off topic but does anyone know the measurements for the friction modifier additive.
