Engine is chugging oil.
Old Mar 31, 2012 | 09:10 AM
  #21
Silver Bastard's Avatar
Silver Bastard
Originally Posted by plott hound
rear main seal? mine was leaking there as well.
It does leak just a little under the truck. Over a two week period I will see a spot about the size of a dime but that deffinately is not a quart.
Old Mar 31, 2012 | 09:14 AM
  #22
Silver Bastard
Here is a pic of the penum gasket and as you can see not much oil inside either....
Old Mar 31, 2012 | 09:44 AM
  #23
peshewa's Avatar
peshewa
It would seem prudent at this time To do a simple Compression test.
Old Mar 31, 2012 | 09:50 AM
  #24
Silver Bastard
This is probably gonna sound stupid but I am not sure how to do a compression test? Is it something I can do or does a mechanic have to do it? Also can I do it while everything is appart as it is?
Thanks!
Old Mar 31, 2012 | 10:45 AM
  #25
So long as the heads are still on, and the valve-train is intact, you can do a compression test.....
Take out ALL the spark plugs.
Put a brick on the gas pedal.
Remove Fuel pump relay from PDC.
Disconnet electrical connector from coil.
(you don't want spark, or fuel, certainly not both at the same time, while testing.)
Screw your compression gauge into cylinder number one. Crank the engine so that the cylinder compresses 5 or 6 times. (or, until the gauge stops going up.) Record the reading.
Take out the gauge, put a teaspoonful of oil into the cylinder.
Put gauge back in, and crank the engine again. (same as above.) Record the reading.
Repeat the process for all eight cylinders.
Ideally, all cylinders should be above 100 PSI, and all within about 25% of each other. Also, no cylinder should jump more than 25% from dry to wet test.
Post your results here, and let us have a look.
Old Mar 31, 2012 | 05:08 PM
  #26
charlie1935's Avatar
charlie1935
If the intake is off, no need to hold the accelerator pedal to the floor.
Old Mar 31, 2012 | 05:13 PM
  #27
zman17's Avatar
zman17
Retired Moderator - RIP
He didn't say hold the pedal to the floor, just put a brick on it.
Old Mar 31, 2012 | 06:07 PM
  #28
charlie1935
Will a 12 lb. sledge hammer work? LOL
Old Mar 31, 2012 | 06:16 PM
  #29
zman17's Avatar
zman17
That might work better. I know for a fact, unless the brick is made of lead, it's not holding my gas pedal down.
Old Apr 1, 2012 | 12:55 AM
  #30
Silver Bastard
I was wondering why I have had leg cramps since I bought my truck????
