Need help with Gears.
Old Mar 26, 2012 | 03:02 PM
KnoCKouT's Avatar
KnoCKouT
Default Need help with Gears.
My Friend has a 2000 Dodge ram Sport, 5.9L 360, I have a 2001 Ram sport 5.9L 360, We decided to have some fun through town, Burnouts and a little racing, We started at the same time and he left me in the dust, 5-8 Truck lengths, He is geared 410, Im curious if there is a way i can check my gears using my VIN or some other numbers? Im running 285/65/18's and hes running 35/12.50/15's, Any reason why his truck has so much more acceleration? My truck has 473** miles and his has 225K..
Old Mar 26, 2012 | 03:27 PM
dodgeguy_sport's Avatar
dodgeguy_sport
you should have a tag attatched to your rear axle telling you what gearing you have. if not, you may be able to find out based on VIN, but i'm not sure on that one. I have 4.10 gears on my truck, but its not that quick, i run 33x12.5s
Old Mar 26, 2012 | 03:50 PM
dlyter09's Avatar
dlyter09
you most likely have the stock 3.55's which would explain your problems.
Old Mar 26, 2012 | 03:56 PM
kejobe's Avatar
kejobe
Check the glove box. Mine has a tag inside with gear ratio and other info.
Old Mar 26, 2012 | 05:36 PM
zman17's Avatar
zman17
Retired Moderator - RIP
You can both get your build sheets here. http://www.dodge.com/wccsapp/univers...ull&category=U
But my bet is , that both of your plenums are blown,the o2's are bad and the cats are clogged. Just his are not as bad as your's yet. LOL
Old Mar 27, 2012 | 11:57 AM
KnoCKouT's Avatar
KnoCKouT
Both of our Cats have been cut, We both run tru duals with 40 series Flows. Ill check the glove box and tell you what we are both geared, How much does it cost to go to 410?
Old Mar 27, 2012 | 12:00 PM
dlyter09's Avatar
dlyter09
Depends on your location and if you can find a good 4x4 shop to do it. Im in Pennsylvania and I can get the gears done for $600 per axle.
Old Mar 27, 2012 | 12:38 PM
gdstock's Avatar
gdstock
How much money you got?
Old Mar 27, 2012 | 05:34 PM
zman17's Avatar
zman17
So that still leaves the blown plenum and shot o2 issue.
Old Mar 28, 2012 | 01:21 PM
KnoCKouT's Avatar
KnoCKouT
How do i check my O2 and busted Phenum's? I have enough money to do a gear swap if necessary, My body shop guy charges 20$ an hour labor, So, My glove box says im geared 410, and my friend thinks he has a junkyard 569 Rearend.
