1998 3500 V10 - P0455 (Unknown missing part)
Old Mar 26, 2012 | 06:08 PM
nz87's Avatar
nz87
Default 1998 3500 V10 - P0455 (Unknown missing part)
I just picked up this truck and I am trying to get it smogged. First it threw a cylindar misfire, changed that whole side of spark plugs and it seems to have gone away. Now I have P0455. I started going through the steps to fix code changed the gas cap, that didn't help. Then I made my own smoke machine (fog machine + Aquarium pump) which didn't seem to work real well. I started looking around and I could smell the gas before I even found it. On the Passenger's side mid-way down going to the rear I found that there is something obviously missing, but I am not sure what it is.
I attached two pictures, but I'll try my best to describe it. If you follow the emissions tubes on the passenger side from the engine bay to the back they eventually make a 90 degree turn to go to the gas tank. This problem area of mine is right where the lines make a 90 degree turn. On my truck there is one canister that looks relatively unharmed, except it is being held up by wire and then in a spot where it looks like the tubes from the engine bay go into "something," there is nothing... They are just exposed to open air. I can see some broken plastic, but I don't even know where to begin to look for a replacement part since I don't know what is missing or what it is called.
Sooo.... What am I missing?
Attached Thumbnails 1998 3500 V10 - P0455 (Unknown missing part)-img_20120326_143842.jpg   1998 3500 V10 - P0455 (Unknown missing part)-img_20120326_143902.jpg
Old Mar 26, 2012 | 06:18 PM
nz87's Avatar
nz87
I'm looking up some parts and it looks like it may be called a Fuel Vapor Canister, but I'm not 100% I would love some confirmation if someone knows.
Thanks
Old Mar 26, 2012 | 06:51 PM
dhvaughan's Avatar
dhvaughan
see these pics.
its relatively easy to fix. you just have to replace any hoses that are missing, rotted, or leaking. if your canisters are broken, get replacements at the junkyard.
you'll need 2 or 3 sizes of hose. about 5/16, about 7/16-1/2", and about 5/8"
https://dodgeforum.com/forum/2nd-gen...-leak-fix.html
Old Mar 26, 2012 | 07:08 PM
nz87's Avatar
nz87
Thanks for the reply. Great to see what it looks like when its not missing. Yours threw a code for having cracked pipes to the canister. Mine is missing the canister entirely, so I'm going to go out on a limb and say that is what it wrong with this truck. Guess I'm taking a trip to the junk yard this week.
Thanks again.
Old Mar 26, 2012 | 09:26 PM
gdstock's Avatar
gdstock
You can go to the FAQ?DIY section and download a service manual and a parts manual. It will all be listed there. I would go with new hoses, but a JY should have the canisters. Good hunting!
Old Mar 26, 2012 | 10:00 PM
JackJ's Avatar
JackJ
Your first pic is of a missing charcoal canister/evap canister the square one is Cali model, the same as on the late 90's jeeps, the round one is a round one usually found in 49 state models. The square one is a dealer only part.
The PO most likely broke the Cali model and rigged in one that he got at a junkyard instead of paying the $90 at the dealer for the right one. The stock one had more hoses connecting to it.
Old Mar 27, 2012 | 07:10 PM
nz87's Avatar
nz87
Thanks for the replies. I'll post again after I fix everything.
