removing coils...
Old Mar 27, 2012 | 01:29 AM
cutthroatxxx's Avatar
cutthroatxxx
Default removing coils...
Ok so I still havent put on my new tires,leveling kit&lift yet planning on having atleast half of the money for my gear swap before I through em on.Then@the same time gonna oaint her.But...when I do I want to pull my coils&blast&paint em.They look like after I remove the. Shock towers they will pull right out is that correct?Thanks
Old Mar 27, 2012 | 07:21 AM
dhvaughan's Avatar
dhvaughan
i'm not sure. with the body jacked up and the front axle hanging and the shock removed - its all loose and ready to come out, but beware there might still be tension on the coil spring. if so - be safe and use a spring compressor to compress it.
Old Mar 27, 2012 | 09:08 AM
Twisted Metal's Avatar
Twisted Metal
+1 for Vaughn(as usual lol) Also the spring compressor will give you some extra wiggle room to remove them. Also you can use it for re-installation.
Old Mar 27, 2012 | 09:53 AM
Augiedoggy's Avatar
Augiedoggy
Your gonna do what to her??
Old Mar 27, 2012 | 09:55 AM
SilverSS's Avatar
SilverSS
Also might want to wrap it with a chain just in case it wants to fly out.
Old Mar 27, 2012 | 10:38 PM
cutthroatxxx
Thank you fine gentlemen
Old Mar 28, 2012 | 01:43 AM
97tn4x4's Avatar
97tn4x4
Disconnect the sway bar for a little more drop on the axle, make it a little easier too.
