ground wire and vacuum hose
Old Mar 27, 2012 | 08:35 PM
snookhooked's Avatar
snookhooked
Default ground wire and vacuum hose
I have a lot of it together at this point on my 318. I asked about the vacuum hose that broke. real thin but its not the one that goes to cruise control. it is at a T but cant find the other end to track it to or from. Its on the same line that feeds everything from the intake and cruise control.
I also have a three end ground that I need to put back but not sure about where one end goes. I know one end is in the rear of the passenger side cylinder head and I am think the middle one attaches to the fire wall but the third end is a question mark? it like a V type. Think maybe somehow its suppose to attach to the other cylinder head? I look ed through all the pictures I took and I dont even see it.
Old Mar 27, 2012 | 10:01 PM
gdstock's Avatar
gdstock
There is a small vacuum line that goes into the firewall for the AC vent controls. Don't know where the ground goes to.
Old Mar 27, 2012 | 10:35 PM
snookhooked
AC vent control. that sound like fun to hunt down.
I was wrong on ground. it went to the back valve cover bolt and I believe the center one goes to the fire wall but I cant remember where there other end goes. book say nothing about ground or where they go. I may have to go look at a similar dodge year and see where its places them.Thanks
Old Mar 27, 2012 | 10:43 PM
gdstock's Avatar
gdstock
You shoule be able to see the end of it sticking out if you shine a good flashlight back against firewall. Pass side, I think right above crank sensor. I have the whoe front end of my Ram masked off where I cannot get the hood open or I would look at ground wires. I don't remember seeing the ground wires when I did my plenum.
Old Mar 27, 2012 | 11:13 PM
snookhooked
Thanks. I will look there. to be honest, I dont know if I broke the hose or it has been. either way, I would like to fix it while I'm in there. being my first time doing this has been stressful but I have learned a lot from it as well.
As to the ground. its a V style look as if it comes from the fire wall to the valve cover. I looked through all the pictures I took hoping to see it but didn't. I dont even understand the purpose of this ground wire other than grounding the motor to the body. Thanks for your help.
Old Mar 28, 2012 | 08:42 PM
snookhooked
Found out that I didn't have a vacuum line broke and I found the ground wire to where they go. they have a ground wire on both cylinder heads. she up and running. in the morning I will start it up and let warm then check all my bolt with a torque wrench.
Old Mar 29, 2012 | 12:43 AM
gdstock's Avatar
gdstock
So where did the end of the thin vacuum line go?
Old Mar 29, 2012 | 12:13 PM
snookhooked
The line wasn't broke but you were correct, it did run into the firewall. I'm now dealing with no air or anything which tells me I have a bad fuse. I turned on everything from air condition to defrost and nothing. I will look at my fuses this afternoon. I haven't done a compression test but everything looking good no leaks and its running good. In fact the oil gauge is responding to my throttle which it didnt before. when I raise the rpms, it goes up with it. temp runs about 180 degrees about a good eighth to left of halfway. no leaking at this point. going to run it some more today since I have to run my wife to her work for a meeting so were taking the Dodge. yee haw
Old Mar 29, 2012 | 12:31 PM
gdstock's Avatar
gdstock
There is a resistor for the blower motor that can go bad. Maybe a search - I have seen it discussed, but not had any persona experience with the problem.
Old Mar 29, 2012 | 01:42 PM
snookhooked
I will have to look that up as well. It was working great before the tear down so I may have either disconnected something I didn't notice or something. other than that, everything seems good so far. I really appreciate all the help here guys. it was a scary but new experience that I have learned from.
