Pro cleen fuel injector cleaner
Old Mar 29, 2012 | 05:31 PM
A_POLVADO's Avatar
A_POLVADO
Default Pro cleen fuel injector cleaner
I borrowed a freind pro kit the one you hook up to the fuel rail. I need to pull the fuel pump relay i was reading up and it said these truck dont use a pump relay they use in other word a fuel stysem relay module I know the relay is in the relay box but it does say fuel system relay.My question is will this just kill the pump or will it kill the injectors as well? i need pump off with the injectors working to clean the system.
thanks for the help
Old Mar 29, 2012 | 05:43 PM
thanks for the help
Fuel relay will only kill the pump. ASD relay powers the coil/injectors.
