Dodge not starting??
Old Apr 4, 2012 | 12:56 PM
Chancock06's Avatar
Chancock06
Default Dodge not starting??
Hey guys, I got a 99 dodge ram 1500 4x4 with a 360. I love my dodge to death but it seems to have thrown a curve ball at me.
The other day I got out of my truck and tried to lock it with the keyless entry but it didn't work. Thought it was odd so I opened the door back up and my dome light did not work, tried to start it and it started for a sec and then died then wouldn't start after that.
I got a feeling it might be my security system but not to sure, all my fuses are good and I assume my relays are as well but not sure on how to check that. Any suggestions would be much help.
Old Apr 4, 2012 | 01:42 PM
PapaG's Avatar
PapaG
Try disconnecting battery and make sure batt posts are clean. This may also reset security system if there's a problem there. (Not sure about that though.)
Old Apr 4, 2012 | 02:15 PM
moss500berg's Avatar
moss500berg
Will it start and stay running if you give it throttle? If so my bet would be the IACV, Mine did the same thing, killed the battery, and wouldnt start and stay running unless i gave it throttle. Its on the back of the throttle body held in by two T15 (i think) screws, take it out and clean it up and see if you have any more luck. If that seems to want to fix it then you should go ahead and replace it, mine was $42 at advance auto parts.
Old Apr 4, 2012 | 02:24 PM
Chancock06's Avatar
Chancock06
Giving it throttle didn't work Either. It almost seems as if the engine is locked up, I can hear my gas pump come on and prime, but nothing. It's only got 60,000 miles on it so I know the engine and parts are fine, it roars when it runs. I think it's the factory alarm that's disabling it. But I don't know to bypass it or reset it.
Old Apr 4, 2012 | 03:18 PM
moss500berg
Hmm.. well there went that. Thats the only experience ive had like that
Old Apr 4, 2012 | 03:20 PM
dodge dude94's Avatar
dodge dude94
Banned Goober Smoocher
Try yanking the security fuse in the PDC box under the hood, maybe?
Old Apr 4, 2012 | 04:33 PM
zman17's Avatar
zman17
Retired Moderator - RIP
Try replacing the plunger switch at the door jamb.
Old Apr 4, 2012 | 10:05 PM
Chancock06's Avatar
Chancock06
It was my power door lock fuse that was blown which is located by the door.
It started right up when I changed it out.
Thanks for all the help guys. Much appreciated!!
