headlight harness upgrade
Old Nov 9, 2013 | 06:56 PM
  #21
Originally Posted by joseortizservin
quick question where is the stock headlight harness?
Attachment 22106
Erm.... plugged into the headlights..... then it disappears into the wire loom.
Old Nov 9, 2013 | 08:04 PM
  #22
joseortizservin's Avatar
joseortizservin
aren't you sopposed to plugg in the other connectors into the headlight and the other plug into the stock headlight harness?
Old Nov 9, 2013 | 08:11 PM
  #23
dhvaughan's Avatar
dhvaughan
no, i don't think so. i think you take the old harness off and throw it away, keeping only the wiring to the switch in the cab. then fish the new yellow harness in and connect to the headlights. mount the relays and connect switch and battery to them.
the advantage of the new is - heavier wire from battery to light. relays. much less amperage to cab switch.
Old Nov 9, 2013 | 08:25 PM
  #24
joseortizservin
yea thats what I did but i cant seem to locate the headlight harness
Old Nov 9, 2013 | 08:37 PM
  #25
Wh1t3NuKle's Avatar
Wh1t3NuKle
The lmc harness plugs into the stock harness. The power goes from battery to relays. Stock switch now switches the relay. Hence no switch problem.
It uses the stock headlight plugs.
Old Nov 9, 2013 | 08:56 PM
  #26
joseortizservin
wh1t3nukle yes i get that but im trying to locate where the 3-prong male connector goes to.
Old Nov 9, 2013 | 09:10 PM
  #27
Wh1t3NuKle's Avatar
Wh1t3NuKle
Due to the length of the harness, your power will be on the driver side.
Unplug the stock portion from the driver headlight. Plug that end into the LMC harness (the box piece in your picture, which looks like my picture). The headlight receives the plug directly from the harness.
Passenger side just leaves the stock plug left a hanging. Lmc plug goes to the headlight.
That help?
Old Nov 9, 2013 | 09:13 PM
  #28
merc225hp's Avatar
merc225hp
Does this kit not come with instructions? Wn will be a great help Op he knows what he is doing.
Old Nov 9, 2013 | 09:31 PM
  #29
joseortizservin
merc225hp it does but are very vague and Instructions do not specify where everything is.
wh1t3nukle yeah its your picture my bad. so i just plug that male connetor that says "existing headlight harness" to the headlight plug on the driver side
Old Nov 9, 2013 | 09:37 PM
  #30
joseortizservin
Talking
wow thanks for the help guys after reading the instructions and re-reading your guys replies I now understand how this harness works.
