Try an solve this temp problem
Old Apr 10, 2012 | 05:35 PM
In your User CP, there is a link on the left "Edit Sig". Click that, and type to your hearts content. (keep in mind, I don't wanna see every minor detail. )
Old Apr 10, 2012 | 05:44 PM
Lemunman's Avatar
Lemunman
i will keep out my tint% and tire pressure out of it hey you
Old Apr 10, 2012 | 05:47 PM
bwdakrt's Avatar
bwdakrt
Is your sensor probe in the radiator at the top hose or the bottom hose? Needs to be at the top hose to get an accurate coolant temp reading.
Old Apr 10, 2012 | 05:50 PM
Thanks.
And: NICE truck........
Old Apr 10, 2012 | 06:22 PM
Lemunman's Avatar
Lemunman
Bwdakrt it's right at the top I think that's right..
Thanks hey you , I have the mopar double roller chain set that you mentioned I should get I'm just hesitant to attempt it Haynes manual makes it look like rocket science .
I've taken down to the lifter valleys 3 times that's easy
Once to fix plenium
Second time lost a 1/2 socket turns out it was on the battery bad habit
Third installing 1.7 used royal purpal assembly lube and pushrod stuck to the rocker when I pulled it away and the rod fell down the hole not happy.
So if its not to bad compared to the intake..some tips might be nice
Old Apr 10, 2012 | 06:43 PM
If you have done the plenum, the timing set is childs play. Some of the same stuff has to come off.... alternator, a/c compressor, and the bracket, after that, take out the fan and shroud, (I followed someone else's advice, and took them out together... did make it fairly easy) water pump, and six more bolts, and the cover comes off. (and coolant goes everywhere.... draining the block first might be a good idea......) Need a puller for the balancer, and a three jaw for the crank gear, once they are broke loose though, they usually just pull right off.
Once you are down to the gears, turn the crank so the timing marks on 'em line up, pull 'em off, Don't Move Anything.... put the new set on, and stick it all back together. (after appropriate cleaning of course.)
Careful taking the cover off. There are two bolts up thru the oil pan, into the bottom of the cover, and tearing the pan gasket is WAY too easy.... a gentle touch, and it shouldn't be a problem. Make sure everything is CLEAN where gaskets have to seal. Coolant passes thru the cover, so, pay special attention to those areas, and a bit of RTV is damn near a requirement. (that, and the sealing surfaces around the coolant ports like to erode... and leave some fairly serious pits... if it's really bad, you can get a new cover, and they aren't hideously expensive....)
It's also a good time to replace the water pump, since you have to pull it anyway......
Old Apr 10, 2012 | 06:54 PM
Ham Bone's Avatar
Ham Bone
Yeah I just recently did the mopar double roller timing chain install along with my plenum. It was really easy.
Just pull the old one off an plop the new one on. It's makes a difference, the engine runs much smoother.
An unless your engine is brand new, expect lots of slack, the original chains wear out really quick.
On the 5.9 the crank bolt pulley is 1 and 1/4 in. I had to really hunt for a socket that big.
Don't forget to lightly oil the chain before covering it back up
Old Apr 10, 2012 | 07:11 PM
Lemunman's Avatar
Lemunman
Sounds a bit more detailed might be a weekdn trip it doesnt seem hard just make sure alot of special attention to alot
Old Apr 10, 2012 | 07:14 PM
Took me a couple hours doing it in the driveway, in the 40 degree weather.... (yeah, that was fun.....) I took frequent breaks.....
Old Apr 10, 2012 | 07:22 PM
Ham Bone's Avatar
Ham Bone
I was doing my plenum fix at the same time, but when I did the chain while my intake was being blasted it only took two hours max to put the new one on and cover it up.
