I have done this on the fox body mustangs alot but never on a dodge same concept real easy to do. but my question. I checked mine it is a .60v on the dodge is it really gonna make a difference if change it to .70v I do have a little stumble coming off idle.Or just leave it alone I have done the search I promise but didnt come across the answer I needed. thnx
I think you are close enough, but try it. Then you can report back with the results. After all, it's pretty easy to do. And don't forget to remove the negative battery cable first.
TPS mod won't do squat on our trucks. When you reset the PCM, at the next startup, it checks voltage on the TPS, and sets that as the zero point. Nothing to be gained from altering it.
