2500/3500 springs in 1500
Old Apr 13, 2012 | 12:28 PM
Djc32294's Avatar
Djc32294
Default 2500/3500 springs in 1500
Im looking for a way to get a couple inches of lift out of my truck. Currently it has a coil spacer in the front and a 2 in block in the back for suspension. Im wondering if i can take a coil spring and leaf packet out of a 2500/3500 ram and have it bolt right up.
Has anyone tried this and had success?
Old Apr 13, 2012 | 12:50 PM
merc225hp's Avatar
merc225hp
Welcome to DF
This has been done on 4x4's many times, if you do a search it will take you to lots of threads on this subject.
Ramcountryboy's Avatar
Ramcountryboy
Coil springs swap out easily, however 2500/2300 leafs are 3in wide, 1500s are 2.5in so you would have to change out the hanger brackets and perches on the axels. Unless you find a 94-96ish LD 2500, they use 2.5in wide leaf springs
