Quick lift kit question
Old Apr 16, 2012 | 08:22 PM
awd1990tsi's Avatar
awd1990tsi
Default Quick lift kit question
Just noticed that the lift kits I've been looking at seem to be for the 1994-01 Ram 1500, Mines a 1994 2500 with the V10, would the one for a 1500 work? or is there a difference in the frames or suspension mounts/design?
Old Apr 16, 2012 | 10:09 PM
Wombat Ranger's Avatar
Wombat Ranger
Difference in spring rates (your motor is heavier, and your truck needs to be able to support more weight) as well as 2500 control arms are slightly shorter than 1500's, since we have larger diameter axle tubes.
Old Apr 17, 2012 | 08:39 AM
awd1990tsi's Avatar
awd1990tsi
Well the towing capacity isn't of huge concern I never tow or haul more than a 1500 would handle. So would the 1500 lift kit work? Or is there a place I can find a lift kit for a 2500?
Old Apr 17, 2012 | 09:09 AM
Matt Nickerson's Avatar
Matt Nickerson
Top Gun Customz has lift kits for 2500s, 4x4s anyways.
Old Apr 17, 2012 | 09:56 AM
gdstock's Avatar
gdstock
Ahhhhh.....No. See Post #3 above. 2X1972 gave you that answer. Do it at your own peril (of parts failing and stuff not fitting).
Old Apr 17, 2012 | 10:46 AM
awd1990tsi's Avatar
awd1990tsi
Oops missed the control arms thing.
Is top gun the only place or are there others that are quality? Thanks for the tip though I'll check them out
Old Apr 17, 2012 | 11:28 AM
Wombat Ranger
And spring rates... The v10 weighs approximately 200 more pounds than a magnum v8.
For lift kits, try:
www.4wheelparts.com
www.ntwonline.com
www.suspensionconnection.com
www.rockymountainsusp.com
Or... www.google.com
Old Apr 17, 2012 | 11:43 AM
awd1990tsi's Avatar
awd1990tsi
I didn't really figure spring rates would make enough of a difference in height. Like in my head, the worst I would of had to do was put in a 2" leveling kit with the front springs
Old Apr 17, 2012 | 11:49 AM
gdstock's Avatar
gdstock
A spring functions to spec in the middle of its range. Overcompression and then inserts will ereduce the effectiove cushioning of springs.
Old Apr 17, 2012 | 12:27 PM
Wombat Ranger
Also forgot this one... Out back HD leaves = 3" diameter, 1500's = 2 1/2" diameter.
And HD's sit approximately 2" higher from the factory, so 4" of lift for a 1500 would be ~2", then factor in spring compression = Not worth it.
