Drop gas tank or tilt the bed
Old Apr 23, 2012 | 11:59 AM
powellcoho's Avatar
powellcoho
Default Fuel pump access - Drop gas tank or tilt the bed
01 Ram 1500 PU, have tracked issues down to Fuel Pump Module Assembly and will be replacing this in my truck. My question - is it easier to drop the entire gas tank to get at it, or could I loosen up the appropriate pu bed bolts and tilt the bed- maybe remove the bed - to get at it?
Any suggestions or past experience - neither looks terribly difficult, just looking to take the most timely route.
Thanks from Duluth, MN.
Old Apr 23, 2012 | 12:22 PM
Pronk's Avatar
Pronk
I'm pretty sure most people choose to remove the bed, it's easier as long as you have more than one person.
Old Apr 23, 2012 | 12:24 PM
merc225hp's Avatar
merc225hp
I believe in dropping the tank, why because you can clean it out much better with the tank out of the truck. It's about 2hrs work in total for the r&r.
Old Apr 23, 2012 | 02:18 PM
zman17's Avatar
zman17
Retired Moderator - RIP
Drop the tank. This way you will also see if the straps and fill tube and hose need replace.
