1996 ABS RWAL Warning Light GRRRR
Old Apr 23, 2012 | 05:27 PM
lefty42303's Avatar
lefty42303
Default 1996 ABS RWAL Warning Light GRRRR
Got abs/brake warning light after heap sits for 2 weeks. Reset light by disconnecting battery. Heap sits another 2 weeks & got light again. Pulled RWAL fuse. Wouldn't reset. Tried jumping OBD 2 terminal 3 to gnd. 4 flashes without long flash. I get 4 flashes, pause, 4 flashes etc. Is this good code? Had to disconnect battery to reset. Did I gnd right terminal? How to diagnose next time this happens? Please!!!
Old Apr 23, 2012 | 05:30 PM
2 or 4 wheel ABS?
For 2 wheel, it's generally the rear wheel speed sensor in the diff.
Welcome to DF!
Old Apr 23, 2012 | 07:01 PM
lefty42303's Avatar
lefty42303
It's 2 wheel drive, 2 wheel ABS, 360cube, 4 speed auto. Service brake works fine. Never tried red neck ABS test! Thanks for the help.
Old Apr 23, 2012 | 08:01 PM
safrantz's Avatar
safrantz
I swear dodge sent out a covert signal to cause trucks to do this...mine did it yesterday while working on my outlet wiring...
Old Apr 24, 2012 | 04:20 AM
93grandzj's Avatar
93grandzj
i feel for yah both. putting leds in the map lights and broke sunglass tab off buddy did it the week before.
post back after fix. my light wanted to stay on longer then usual tonight when i left work( about 30 seconds)after startup.
Old Apr 24, 2012 | 05:27 PM
zman17's Avatar
zman17
Retired Moderator - RIP
If it sat for a while, just try removing and cleaning the plug/connection to the sensor on the rear diff housing. After cleaning, put it on and off a few times. May just be a corroded connection.
Old Apr 25, 2012 | 01:14 AM
93grandzj's Avatar
93grandzj
thanks will look at it this weekend.
