mopar meltdown
Old Apr 30, 2012 | 08:10 PM
d.lanaville's Avatar
d.lanaville
Default mopar meltdown
i have a 98 dodge 1500 with the 5.9 L. 4x4. i went to go out and change my front passenger u joint. and that turned into me breaking the hub. which then turned into me bending the yolkes where the u joint goes in. and at the end of it. i need new tie rods. any suggestions/ help would be very helpful.
Old Apr 30, 2012 | 08:38 PM
Wombat Ranger's Avatar
Wombat Ranger
Okay a tie rod is one of your steering links. If you think you need new axleshafts, they should be easy to find at your local junkyard. Around here I can pull one for $20.
Old Apr 30, 2012 | 09:17 PM
d.lanaville
thanks man. but when i wne to tgo and pick out the axel shaft. i picked up one for a half ton. got it to the house and realized that it wasnt right splines. then one that came out of my truck had nice and deep splines. this one that i pulled had shallow shalklow splines. is that grounds for me having a 3/4 ton front end?
Old Apr 30, 2012 | 10:26 PM
What does it say on the door? How many lugs on your wheels?
Old Apr 30, 2012 | 10:34 PM
d.lanaville
the doors dont have any thing exept the ram 1500 v8 magnum on the out side. and its got 5 lugs
Old Apr 30, 2012 | 11:05 PM
QuadCabLuv's Avatar
QuadCabLuv
5 lugs mean 1/2 ton
Old Apr 30, 2012 | 11:28 PM
d.lanaville
that front end houseing says dana 41367 026 8. and when i compared my axel shaft to the one that i picked up for a 95 1500 they were completely different. mine had alot deeper splines compared to the very shallow ones on the 95
Old May 1, 2012 | 12:31 AM
gdstock's Avatar
gdstock
Inside the driver door jam should be a white tag with truck info there.
Old May 1, 2012 | 07:21 AM
zman17's Avatar
zman17
Retired Moderator - RIP
There should be info on a sticker on the rad support and one in the glove box.
Old May 1, 2012 | 10:31 AM
Wombat Ranger
Is it possible that a previous owner upgraded to stronger axleshafts? A good indicator would be if the truck has a locker up front, lift/tires, etc.
