no power to ac
Old May 2, 2012 | 10:24 PM
blitzline's Avatar
blitzline
Default no power to ac
My ac went out a last summer and I left it alone all winter but with warm weather coming I would like to try to fix it. I went to see if I could get it to work today and it wouldnt. I checked my incoming power at the plug and am not getting any power there. could someone help me figure this out. Im not super savy on electrical problems. Its a 95 1500 5.9l v8
thanks
Old May 2, 2012 | 10:40 PM
DK-v1's Avatar
DK-v1
Where did you check power?
When you turn to blower motor **** to full blast, does it do anything?
Old May 2, 2012 | 11:20 PM
blitzline's Avatar
blitzline
i checked power at the plug that goes into the ac. When i turn the blower **** all the way up it blows on high and it works on low so its not the switch. checked the relay and the relay is good
Old May 3, 2012 | 12:36 AM
gdstock's Avatar
gdstock
There is a 20 amp fuse to compressor clutch. Also, if refreigerant is too low or too full, the hi or low pressure switch will keep it from running. The fuse on a 1999 is in the PDC first row, second fuse from the fender.
