Loud Noise From Front End?!
Old May 3, 2012 | 12:42 AM
badrhino's Avatar
badrhino
Default Loud Noise From Front End?!
I have noticed a loud noise come from the front end. I think? It only does it every so often. I just had new tires put on and then had to have all 4 new ball joints installed and then had it aligned. Now I hear a loud noise come from the front once in a while (I mean I went for about a week without hearing it/ or It will do it 2-3 times in a day). It is scary sounding and you can even feel a vibration when it happens. The sound is loud, banging almost-clanking, then it goes away.
At one time I was thinking it could have been the drive shaft U-joints. But it sounds like the front passenger side of the vehicle. Can a front wheel ball bearing going out make this type of noise/commotion?
Any suggestions?
Old May 3, 2012 | 08:46 AM
Jack up the front end, and inspect everything. Might be as simple as a shock bolt not being torqued enough. (them fellers need to be torqued to like 100ft/lbs.....)
Old May 3, 2012 | 09:02 AM
zman17's Avatar
zman17
Retired Moderator - RIP
Check the vacuum lines going to the CAD also.
Old May 3, 2012 | 09:21 AM
QuadCabLuv's Avatar
QuadCabLuv
Also inspect for any midgets you ran over that may still be under your truck
Old May 3, 2012 | 11:31 AM
badrhino's Avatar
badrhino
It's a 2-Wheel Drive so I doubt it's the CAD. And I don't remember running over any midgets lately. LOL
Any other ideas?
Old May 3, 2012 | 11:37 AM
zman17's Avatar
zman17
Any other ideas?
That info would make a great addition to your sig and profile, you think?
