Cleaning Lifter Valley before new oil pump
Old May 7, 2012 | 07:05 PM
DodgeRam10's Avatar
DodgeRam10
Where is a good pry point for the main bearing cap? I got the bolts off and have been hitting it with a mallet and trying to pry with a screwdriver but i dont want to jack anything up,any tips on getting it off?Seems pretty bonded to it..
Old May 7, 2012 | 07:37 PM
I used a long punch, stuck it in one of the bolt holes, and just wiggled it a bit, and the cap came off. Yeah, they do tend to hang on fairly tight.
Old May 7, 2012 | 08:09 PM
DodgeRam10's Avatar
DodgeRam10
ok ill keep trying, also while i was giving this a break i was finishing up the timing. Im installing the new seal but what about this sleeve? Ive read it goes over the harmonic balancer but what if mines smooth? Can i just put it on anyway? Just didnt want to go back to the parts store if not needed.
Old May 7, 2012 | 08:20 PM
Ham Bone's Avatar
Ham Bone
If you have the gasket, an the timing cover isn't bent up or anything. Just clean all the surfaces Very thoroughly and pop it on
Old May 7, 2012 | 08:24 PM
DodgeRam10's Avatar
DodgeRam10
its not the gasket its the seal, i no the seal with the sleeve the inside diameter is a lil bigger to accomodate the sleeve. my harmonic balancer is smooth so i dont really need the repair sleeve but dont really want to go drive to the parts store to get the "normal" crank seal.also i got my cap off should i put oil on the rear main before installation or do it dry, if oil where should i put it.
Old May 7, 2012 | 08:33 PM
See how the seal fits on your balancer. If it will seal. don't worry about it, if it won't, you can either return the gasket kit, and get the one without the sleeve, or, try and install that damn sleeve. I have found they are a pain..... I would rather just replace the balancer, than try and get the crazy sleeve to go on there.
Old May 7, 2012 | 08:45 PM
DodgeRam10's Avatar
DodgeRam10
ok ill figure something out with that. also the fsm says to lightly oil the rear main seal lips, so im assuming thats both sides?
Old May 7, 2012 | 08:52 PM
I just stick my finger in some oil, and rub it on the seal. get it wet. good enough.
Old May 7, 2012 | 09:01 PM
DodgeRam10's Avatar
DodgeRam10
ok, i got the sleeve on the harmonic balancer figured it couldnt hurt to try, got the seal in i believe all the way but cant remember if its flush with the timing cover or not, right now its about an 1/8 or 1/4 out. manual didnt really specify
Old May 7, 2012 | 10:51 PM
Knock it in flush.
I am impressed you got that sleeve on there. I have zero success with those....
