Shaking while driving
Old May 8, 2012 | 12:07 PM
jarebear86's Avatar
jarebear86
Default Shaking while driving
When I get up around 45-50 I have a small shaking while driving like it's the motor not having enough oil or running rough. It's not the tires being unbalanced and I just changed the plneum gasket last weekend and there's plenty of oil. Also of i just slowly accelerate it stops. What y'all think it could be?
Old May 8, 2012 | 12:17 PM
Pull the spark plugs and have a look. Sounds like you have a miss.
Old May 8, 2012 | 12:36 PM
zman17's Avatar
zman17
Retired Moderator - RIP
Was the cat checked? And did you replace the o2's? And spark plugs like HeyYou stated?
Old May 8, 2012 | 03:35 PM
stewie01's Avatar
stewie01
#8 plug tends to foul out pretty commonly, did you replace the plugs when you did the plenum?
Old May 8, 2012 | 03:46 PM
johnnyjaws98's Avatar
johnnyjaws98
bent rim?
Old May 8, 2012 | 05:21 PM
elevated81's Avatar
elevated81
ujoint? *cough*
Old May 8, 2012 | 05:33 PM
peshewa's Avatar
peshewa
Cocaine is a very powerful drug....
Old May 8, 2012 | 08:35 PM
jarebear86's Avatar
jarebear86
No bent rim don't believe cat is clogged and replaced all plugs during plneum swap. I did forgot to check distributer cap and rotor though but I replaced those about a month ago bc they were messed up
Old May 8, 2012 | 08:43 PM
Did you route your wires per the TSB in the FAQ section?
Old May 8, 2012 | 09:43 PM
jarebear86's Avatar
jarebear86
Huh???
