looking into getting gears, need help
Old May 8, 2012 | 11:13 PM
DK-v1's Avatar
DK-v1
How would 4.10s on stock wheels/tires do? Better/worse on mpg?
Old May 9, 2012 | 02:01 AM
Wombat Ranger's Avatar
Wombat Ranger
After lifting the truck and putting on bigger tires you will always get worse mpg's, due to more resistance. But you can get most of it back with optimum tuning and gearing. If I was you I would go with 4.56's, as previously stated, so that WHEN you put a 3" body lift on it and go to 35's you will be prepared and even if you never do, the extra power will make it more fun to drive and tow with.
Old May 9, 2012 | 08:29 AM
MudFever's Avatar
MudFever
I put 4.56's and I love it with 35's....
Old May 9, 2012 | 08:31 AM
Depends on what kind of driving you do. Around town, you would probably get better mileage, on the freeway, not so much so.
Old May 9, 2012 | 08:57 AM
Augiedoggy's Avatar
Augiedoggy
Originally Posted by 97_ram1500
im hoping so. too bad it isnt coming from the engine where it belongs. haha (yet)
it is.... the 3.55 gearing robs the power from the drivetrain... 4.10 or 4.56 gears deliver more of that power to the ground... with the lift you have more wind resistance and bigger tires change the gear ratio as well as add weight so the 4.56 gears with the 33" tires might not be a bad idea... especially if you drive up a lot of hills or tow.
Old May 9, 2012 | 09:27 AM
zman17's Avatar
zman17
Retired Moderator - RIP
@ 97_ram1500 I assume the plenum has been checked?
Old May 9, 2012 | 06:08 PM
2 Marks's Avatar
2 Marks
33" and 4.56 are perfect. Gained MPG and tons of power.
Old May 9, 2012 | 06:39 PM
lastrights's Avatar
lastrights
What did you guys do about front axels with the 4.56 gears ?
Old May 9, 2012 | 06:56 PM
Wombat Ranger
Get thick cut if you don't want a locker, and re-use the stock carrier.
Old May 9, 2012 | 07:01 PM
2 Marks's Avatar
2 Marks
Going from 3.55 tp 4.56 required a new carrier. I think the cutoff is after 3.73 give or take. If you go 4.10 from 3.55 you will need a carrier.
