PCM Replacement on 1994 Dodge ram 5.9l
Old May 9, 2012 | 09:38 PM
kurtis500's Avatar
kurtis500
Default PCM Replacement on 1994 Dodge ram 5.9l
So I have it down to the PCM which needs replacement. Question is, do I need to re-program the old OBD-1 computer? Can I use the unit straight from Autozone?
Old May 9, 2012 | 09:52 PM
If the new one is set up for your engine size, and trans, just stuff it in, no programming involved. (mainly because, you can't....)
I wouldn't trust an autozone PCM though.... I would check junkyards before I would buy one from them.
Old May 10, 2012 | 02:03 AM
Wh1t3NuKle's Avatar
Wh1t3NuKle
But at least you can take it back to Autozone and not the JY....right?
Old May 10, 2012 | 09:48 AM
Only if you have something else to drive.
Old May 10, 2012 | 10:25 AM
zman17's Avatar
zman17
Retired Moderator - RIP
The jy's I go to have at least a 14 day warranty.
