'98 which manual to use '96 or '01
Old May 13, 2012 | 11:59 PM
Moochoff's Avatar
Moochoff
Default '98 which manual to use '96 or '01
I've been searching through the manuals in the DIY section. which manual should I download and stick with? I'll be doing the main and rod bearings.
I also picked up a mopar rebuilding for dummies type text book
Thanks
And while I started another useless thread for most searchers. Can I reuse my oil pan gasket? its only a couple weeks/10 miles old with no sealant or gasket glue applied
Old May 14, 2012 | 08:18 AM
01 manual is going to be closest for you.
If you got the good rubber gasket, should be able to re-use it.
Old May 15, 2012 | 02:27 AM
Moochoff's Avatar
Moochoff
If this forum had a thanks button for posts. Im guessing you would be well into the 1,000's.
And as always, thanks for your time HeyYou!
