What's wrong?
Old May 14, 2012 | 07:49 AM
Sdwight's Avatar
Sdwight
Default What's wrong?
My 1996 Ram P/U didn't start this morning. Acted like battery was dead. Jump started it, but it would not keep running. Any ideas of what the problem is. Could it be just the battery?
Old May 14, 2012 | 09:25 PM
jasonw's Avatar
jasonw
Site Moderator
https://dodgeforum.com/forum/dodge-r...s-section.html
Old May 14, 2012 | 09:34 PM
dhvaughan's Avatar
dhvaughan
low battery voltage causes idle problems with IAC voltage.
charge or replace battery and give it a chance to fix itself.
Old May 14, 2012 | 10:30 PM
DK-v1's Avatar
DK-v1
Could be that a rat worked itself into your truck the night before and found a tasty copper treat...I've seen that happen.
Old May 14, 2012 | 10:38 PM
gdstock's Avatar
gdstock
Check the items above, and also go to the FAQ/DIY section and download the service manual and the parts manual for your truck.
Old May 15, 2012 | 10:38 AM
billcart's Avatar
billcart
If you jump started it and it started keep the idle at 3k rpm for about 10 minutes for the idle to re-learn itself while you have the two batteries in series. This has happened to me at the beach running my radio and killing my battery. Not often but it does happen.
Old May 15, 2012 | 10:38 PM
dhvaughan's Avatar
dhvaughan
i'm calling BS on this one.
holding the rpm at 3K will recharge the battery which fixes the problem.
but the pcm can't relearn the idle at 3000 rpm.
Old May 15, 2012 | 11:03 PM
gdstock's Avatar
gdstock
+1 on this.
Old May 16, 2012 | 02:50 PM
billcart's Avatar
billcart
When I said "re-learn" itself it a slang term down here meaning of you jump, start it and it doesn't stay running you have to hold throttle down for about 10 minutes before you can let off. You said PCM not me. So quick to judge dhvaughan and gdstock
