no power at a/c plug - ever
Old May 16, 2012 | 03:36 PM
peshewa's Avatar
peshewa
Default no power at a/c plug - ever
Hey guys, I have a non-working a/c, not uncommon on it's own, but I took the clutch molex loose & turned it on with the engine running & the volt meter measured nothing from either wire alone when grounded to the block, or to each other directly. I can almost do without the a/c, but I also want to run a wire for my efans to it so they start automatically when I turn on the a/c also. Any ideas?
Old May 16, 2012 | 03:43 PM
peshewa's Avatar
peshewa
I also verified that the fuses are good also.
Old May 16, 2012 | 04:52 PM
Verify that fuse J in the PDC is good. (10 amp)
Verify that you have power at pin 30 on the A/C relay.
If that looks good, swap the a/c relay with another one. See if anything changes.
and if that ain't it......
Verify at least 5 volts on the brown wire at the a/c low pressure switch. (on accumulator.) Make sure you have power on the other side of the switch as well. (with it plugged in.....) If not, either low A/C charge, or bad switch.
If that's ok, check the high pressure switch...... see if you have voltage to/across it.
Old May 16, 2012 | 04:55 PM
zman17's Avatar
zman17
Retired Moderator - RIP
Low 134a I'm going with.
Old May 16, 2012 | 05:41 PM
hillbilli's Avatar
hillbilli
Second the 134a.
If the charge is too low, the low psi switch wont allow the A/C clutch to engage. Start with a can and see if the clutch engages.
Old May 18, 2012 | 03:07 PM
peshewa's Avatar
peshewa
Thanks guys! I will check it out later today for sure. Heyyou, thanks for the very complete advice too.
