advice on rear end
Old May 31, 2012 | 09:30 AM
  #21
toma3729's Avatar
toma3729
I had moaning on excelleration and replaced inner, outer bearings seal and axel bearings with seals and what dream ride. If you are pulling out the Spyder Gears to do the bearings and seal, why not replace anything that you suspect of damage from the brakes to the pinion seal rather than have to open her *** up again? JMO
