99 Ram 4x4 Quad Pulling with overdrive on
Ok, so if I install a temp gauge, do you guys see problems with me from time to time turning the OD back on. Say I pull at 60 - 65 level ground and watch the temp gauge. If it does not move much would I be safe to pull the 3840 pound boat with the OD on from time to time? Is it temp that destroys the OD and tranny, or too much pulling on the OD that tears up the tranny?
Thanks
Thanks
Now that you have the gauge installed. You'll notice that even driving around town with OD on(with no towing) creates more heat and the tranny will run hotter than if you turn OD off, unless you are on the highway.
Damn, two threads.
Damn, two threads.
