transfer case oil
Old Aug 17, 2005 | 06:16 PM
venado's Avatar
venado
Default transfer case oil
i own a 1997 4x4 D. Ram and i want to change the transfer case oil what type or grade of oil shuld i use
thanks
Old Aug 17, 2005 | 07:03 PM
The Burning Rom's Avatar
The Burning Rom
Default RE: transfer case oil
http://dodgeram.org/tech/specs/tranfer_case.htm
If your vehicle is a 1/2 ton (1500), you have a 231 transfer case. If it is 3/4 ton or larger, you will have to check the sticker on the underside of your hood to see which transfer case you have.
