1995 Ram 1500 torque converter question
Old May 23, 2012 | 08:28 PM
newport74's Avatar
newport74
Default 1995 Ram 1500 torque converter question
I ordered what I thought was the right converter for my truck after pulling the trans and checking the code (878) the one I ordered is code 514.
After comparing the specs on both these converters I can find the only difference seems to be one tooth on the flywheel ring 130 vs 131 teeth.
My question is will the one I have work or should I send it back for the other there are applications where the 878 or the 514 will work just not sure If I can get away with it in my trans.
Thanks in advance
Newport74
Old May 26, 2012 | 12:17 AM
jasonw's Avatar
jasonw
Site Moderator
https://dodgeforum.com/forum/dodge-r...s-section.html
Old May 26, 2012 | 12:24 AM
gdstock's Avatar
gdstock
Thanks in advance
Newport74
One more or one less tooth will effect the pitch, so it will not match starter, and eventually, one or both will get chewed. I would return to vendor and get correct one.
Spline may be differnet as well.
Who did you get it from? Shipping may be a killer, but seller should eat that if it was their mistake.
