help tie rod adjustment sleeve
Old May 24, 2012 | 05:34 PM
gdstock's Avatar
gdstock
Have we complicated the reapir yet?
How worn is the steering system? Although not likey, is that the only part that is worn or damaged?
Old Dec 2, 2024 | 06:21 AM
Shanedriver's Avatar
Shanedriver
Default Tie rod adjustment sleeve bolt
On my driver front I tried to realign it when I went to tighten the bolts on of the bolts would not stay in place so I can tighten the nut on it has a flat top with the square on it and the square part was just spinning it's self and I can't get the nut to it on of off to replace it it's a 99 Dodge ram1500 5.9l I'm stuck and I have to make an 1hr and 13min drive everyday
Old Dec 2, 2024 | 09:15 AM
Can you grab the head of the bolt with a wrench, or vice grips?
Old Dec 2, 2024 | 10:04 AM
Shanedriver
No I can't it's a stovetop bolt
Old Dec 2, 2024 | 10:13 AM
Ah, one of those.....
Got a hack saw? Cut it off. Replace it with a nut/bolt.
Old Dec 2, 2024 | 10:45 AM
Keith_L's Avatar
Keith_L
Yep, tack weld or cut it off and replace
