46rh solenoid voltage
Old May 29, 2012 | 11:05 PM
EndlessApex's Avatar
EndlessApex
Default 46rh solenoid voltage
Hello,
I have a 96 1500 and the front seal on the RE went, long story short I thought it was a 95 not 96 so I now have a RH installed in the truck, and didn't realize until I went to plug the 8 pin connector in.
I went to a local yard and grabbed a pigtail for the 3 pin connector of the RH and plan to just wire two switches for the OD lockup and TQ lockup. The colors on the chassis side of the 3 pin connector are Brown, Orange w/black trace, and Green w/black trace. Does anyone know which is the constant power and which are TQ / OD?
Also, going by a pinout I found for the 8 pin connector on the RE, it seems the power supply is 5v. Does this mean on the RH my constant power needs to be 5v's not 12v's? Any help would be much appreciated, I understand this is NOT the right way to do this but I don't drive the truck much and really don't have time to source another trans, or pay the 25% restocking fee to the yard I got the RH from.
TRANSMISSION SOLENOID ASSEMBLYCAV CIRCUIT FUNCTION
1 T16 18RD TRANSMISSION CONTROL RELAY OUTPUT
2 K7 18OR 5 VOLT SUPPLY
3 K4 18BK/LB SENSOR GROUND
4 T25 18LG/WT GOVERNOR PRESSURE SIGNAL
5 K88 18VT/WT VARIABLE FORCE SOLENOID CONTROL
6 T60 18BR OVERDRIVE SOLENOID CONTROL
7 K54 18OR/BK TORQUE CONVERTER CLUTCH SOLENOID CONTROL
8 T54 18VT TRANSMISSION TEMPERATURE SENSOR SIGNAL
Figured I'd throw this in here to make the Thread more interesting. I welded the diff in the truck a while ago and it slides surprisingly well. This is probably why the RE failed, hopefully the RH handles it a little better.
http://youtu.be/MOjBBOLfqVY
Old May 30, 2012 | 09:35 AM
Brown wire is O/D solenoid control.
Light Green with Black trace is 12 volt supply. (switched ignition)
Orange with Black trace is TCC control.
RE trans uses 5 volts for pressure/temp sensor. The RH doesn't have either. (on the inside at least.) If your trans has a temp sensor, it will be mounted on the trans line, very near the transmission itself.
Old May 30, 2012 | 07:07 PM
EndlessApex
Beautiful, you're the man.
