Cat Converter Replacement
Old Jun 6, 2012 | 10:06 PM
Big White Farm Truck's Avatar
Question Cat Converter Replacement
My truck had all the symptoms of the dreaded plenum failure so I checked it and it is bad, leaning toward the repair kit from Hughes. I figured while I was at it I would check the codes and a oxygen sensor code came up so I checked the #8 plug, which isn't that old, and found it was completely black which proves that the cat is plugged. Which is the best replacement cat available?
Old Jun 6, 2012 | 10:10 PM
MagnaFlow direct fit replacement. Flows better than stock too. Can be found in various places for under 200.00.
Old Jun 6, 2012 | 10:13 PM
kejobe's Avatar
kejobe
Best?? Alot of people like either stock replacement or Magnaflow high flow. Some claim either check engine light and/or loss of low end with the high flow.
Cheapest?? Gut the thing. Same side effects as high flow, but doesnt cost anything if you have a welder to weld it back on yourself ( or a section of pipe).
Either way, if you get a cel just do the nonfouler "mod".
As far as brands for OEM?? I dont really know.
