need help adjusting camber on a 97 4x4
Old Jun 12, 2012 | 01:20 AM
phelsel's Avatar
phelsel
Default need help adjusting camber on a 97 4x4
I was looking for some advise i need to install adjustable ball joints to correct for negative camber out of specs on my 97 ram 1500 4x4,
i was wondering if i could just use adjustable's on the lowers and just replace the uppers with OEM replacements or if i should split the difference between the upper and lowers? drivers side needs +1 degree passenger +1.5 degrees to set both at .2 degrees almost right in the middle of manufacture specification. also and guidance on installing them properly would be much appreciated.
Old Jun 12, 2012 | 02:04 AM
dodge dude94's Avatar
dodge dude94
Banned Goober Smoocher
IIRC these trucks have a little bit of negative camber built-in from the factory to make them track straighter. According to the 2001 Factory Service Manual, the camber is not adjustable and is fixed.
Why do you want to correct the factory camber? Too much tire wear or is it even worse than factory spec?
BTW, Welcome to DF!
Old Jun 12, 2012 | 07:11 AM
dhvaughan's Avatar
dhvaughan
no personal experience, but this might help.
http://www.moogproblemsolver.com/_pd..._Adj_BJ_En.pdf
Old Jun 12, 2012 | 08:50 AM
phelsel's Avatar
phelsel
Yeah tne insides of my tires are wearing bad, they are out of factory spec, wich is -.3 to .8
Old Jun 12, 2012 | 03:31 PM
zman17's Avatar
zman17
Retired Moderator - RIP
More than likely the axle tubes have collapsed or streering knuckles are bent. dhvaughan's suggestion is the best course of action.
Old Jun 12, 2012 | 05:58 PM
phelsel's Avatar
phelsel
No its off becuse of the lift but like I asked, do I ned to split the differance between uppers and lowers or can I just replace the lowers with the ajustable s and oem uppers
Old Jun 12, 2012 | 06:31 PM
stewie01's Avatar
stewie01
Did you get an alignment after the lift?
Old Jun 12, 2012 | 06:46 PM
phelsel's Avatar
phelsel
Yes thats how of know how much I need to adjust the camber
Old Jun 12, 2012 | 06:53 PM
stewie01's Avatar
stewie01
Why didn't/couldn't the alignment shop do it?
Old Jun 12, 2012 | 06:55 PM
phelsel's Avatar
phelsel
They wanted 600 bucks to do it
