new 408 dies
Old Jun 16, 2012 | 11:24 PM
Wombat Ranger's Avatar
Wombat Ranger
Me too, only, unlike gdstock, I can't fund it at the moment...
Old Jun 17, 2012 | 12:12 AM
gdstock's Avatar
gdstock
I spent a couple hours clearing our some storage and shelving in the garage and moving to a storage building out back.....and there just s happend to be enough room to bring my engine stand back into the garage.......hmmmmm.
And back on topic.....+ 1 on injectors and tune.
Did you change injectors or use the origninal ones? Also, get the specs on what you did to Sean and Hemifevertuning.com and see what he can do for you. That thing ought to run like a striped ape when you get this done. What did you do for intake?
And _ +1 MORE on pics!!!!
Old Jun 17, 2012 | 12:31 AM
Derick C.'s Avatar
Derick C.
Scat 408 crank, eagle rods, KB hyperutectic pistons, comp cam gross valve lift .480 duration @ .050 212 intake and 218 exhaust. Stock intake manifold, stock injectors reworked by dr injector. Sounds like the machine shop screwed me telling me the stock computer tune will work fine.
Old Jun 17, 2012 | 12:35 AM
Derick C.'s Avatar
Derick C.
Originally Posted by Adobedude
Stock fuel system will feed a 408, but not the stock injectors and you WILL need a SCT tune to make it work, as said your fuel sync needs to be set, but where you set it depends on your build. +4 is safe.
More info on the build please....And quit trying to run it before you kill it.
Just dropped a 408 in my Dakota this month....412 RWHP
How do you set the fuel sync.
Old Jun 17, 2012 | 02:00 AM
gdstock's Avatar
gdstock
Gotta use a scanner or computer that has the ability to set it. Something like a Snap On MT 2500 will do it. Others also, but not sure which other ones.
How di they rework stock injectors?
Old Jun 17, 2012 | 02:07 AM
Hahns5.2's Avatar
Hahns5.2
Stock tune+bigger injectors+fuel sync not set+48 more cubes is gonna run like garbage.
Drill the holes bigger with tiny dental drills. I have a set of 42lb injectors from FIC that were modified from their stock size. They're flow matched too.
Old Jun 17, 2012 | 02:10 AM
gdstock's Avatar
gdstock
It costs money to do this? Shoooot!
Old Jun 17, 2012 | 10:22 AM
QuadCabLuv's Avatar
QuadCabLuv
Would some 4hole ford injectors not suffice?
Old Jun 17, 2012 | 10:37 AM
Derick C.'s Avatar
Derick C.
Not sure how they do it but they said they will feed a 408
Old Jun 17, 2012 | 01:52 PM
gdstock's Avatar
gdstock
So if a guy decided to build a stroker...not saying anyone is thinking about it....where would one find out everything he would need and everything he would need to know?????
