some help please.
Old Jun 16, 2012 | 11:51 PM
king_moaoe's Avatar
king_moaoe
Default some help please.
i just sold my 96 1500 with 200k miles and went and test drove a 99 2500 with 145,000 well everything was great, until i looked underneath. the oil pan and in front like on the front dif and above the oil filter. the truck is 5000, what should i do? should i keep going through with the deal.
Old Jun 17, 2012 | 12:07 AM
gdstock's Avatar
gdstock
It may depend on what this means????
And I don't know about where you live, but that is way too much in my area....
Old Jun 17, 2012 | 12:31 AM
king_moaoe's Avatar
king_moaoe
what do you mean by to much for where you live? it is coated in oil that has absorbed dirt making the caked on grime. i found a leak coming from the seal around the oil plug and i think the oil filter is another source since most grime is right around it.
Old Jun 17, 2012 | 02:04 AM
gdstock's Avatar
gdstock
That year truck can easily be had for $3000 where I live. Prices vary based on where you are.
The oil could be anything. Pan gasket, oil filer seal. Neither is a really big issue to fix. Another source of oil all over - check valve cover bolts. Bet they are loose. This will allow to run all over back and down the side of the engine.
Old Jun 17, 2012 | 08:59 AM
redneck_ram's Avatar
redneck_ram
99 2500's around here catch 1-8k depending on milage, condition, 2wd or 4x4, type of cab. i got my 2001 1500 for 2800, had 150k on it and that was 3 years ago.
Old Jun 17, 2012 | 11:30 AM
king_moaoe's Avatar
king_moaoe
How do I check valve cover bolts? Usually I like to figure out on my own but not with 5000 riding on it.
Old Jun 17, 2012 | 11:38 AM
Put a socket on 'em, and see if they are loose. Fairly standard for these trucks.
Old Jun 17, 2012 | 01:02 PM
king_moaoe's Avatar
king_moaoe
Thank you heyyou but my real question is where is the valve cover bolts located
Old Jun 17, 2012 | 01:08 PM
QuadCabLuv's Avatar
QuadCabLuv
they are located on the valve covers.....
Maybe you outta take it by a shop and pay them the $30 they usually charge to go over it and inspect it
Old Jun 17, 2012 | 01:44 PM
gdstock's Avatar
gdstock
OK. See the blue things there? One on driver side, one on passenger side. (yours are probably black, but in my garage, if soomething is around very long, it tends to change colors).....
There are either eight or ten bolts around the bottom edge on each cover. I think the bolts are either 10 or 12mm. Tighten them to around 14 ft. pounds.
Also, if you go HERE, you can download factory service manual. You will need this....
AND....what part of the country are you in? And if yoiu go to UserCP at the top left of the page, click on "EDIUT SIGNATURE" and put your truck info there, we will all know and you won't have to enter it each time....
