HID and a 01 Ram
Old Jul 8, 2012 | 04:04 PM
  #51
bent-fender's Avatar
bent-fender
Why not run the down the fire wall and Im still not getting how that one plug will make 2 lights work. I get how evrything mounts and or plugs up from pulling my lights to installing the ballast. I get all that I get how the harness bolts and plugs up as well just dont get how one will make 2 work is all. I guess I will see when it comes in. Also Dbrown keep checkin here I may need to pick your brain when mine comes in.
Old Jul 9, 2012 | 12:58 AM
  #52
Prototype's Avatar
Prototype
As long as you plug in one of the original light plugs into the blue connector it will work. Like I said, the original light plugs are only used as a trigger now instead of being the power supply. The relay harness will become the new power supply.
Old Jul 10, 2012 | 01:40 PM
  #53
bent-fender
Originally Posted by Ebay
The item was shipped via economy air shipping. there are no tracking number.
it usually take 14-20 days for delivery
Looks like it is going to be a while before I get to use my lights.
Old Jul 17, 2012 | 05:26 AM
  #54
bent-fender
ok some one please tell me how this harness hooks up. Also do ya'll said sswapp the high low beam wires right?
Old Jul 17, 2012 | 11:03 PM
  #55
bent-fender
Originally Posted by beeker
Are you using a Bi-Xenon relay harness?
The relay harness may be wired as a 9007 instead of 9004, they all seem to come that way regardless the kit says it's a 9004. The low beam and ground wires need to be switched. Slide a small screwdriver in the plug to release the wires and rewire as shown. Check with a multimeter to prevent damage to the circuits and wiring.
Ok mine are red black thin red no blue. And the stock wiring is red, purple with white stripe and Purple.
I installed the kit all is great 2 issues Flicker on one setting and the high bean indicator stays on. I bought the harness that YOU GUYS suggested and I havent got anywhere with it.
I NEED HELP with this please. Im completly friggin lost.
Old Jul 17, 2012 | 11:21 PM
  #56
bent-fender
Originally Posted by Dbrown016
This is the tutorial i followed yesterday while installing my HID and relay. Took me like 20 minutes to install just because it was my first time. Easiest tutorial on youtube. i can take pictures as well if you need them!
http://www.youtube.com/watch?v=Ix38mjyeFLQ
From what i can see there is no power going to the light that he taped off.
Yes pics and info would be great
Old Jul 18, 2012 | 01:32 AM
  #57
Prototype's Avatar
Prototype
Okay, since you say your harness doesn't have the right colours, just do it mentally, switch around what would be the red and the black wires, after that your high beam indicator should go off and the lights should work no problem. I've never seen a harness that used different colour wires, unless it was home built, so maybe you could take some pictures of that for us?
Old Jul 18, 2012 | 01:20 PM
  #58
bent-fender
I will get pics friday. So I have to do this on the truck side and not the hid lights them selves?
Old Jul 18, 2012 | 01:24 PM
  #59
Yep, truck side.
Old Jul 19, 2012 | 04:24 PM
  #60
Prototype's Avatar
Prototype
Yep, truck side.
err.. He needs to switch the wires around on the harness side.. not the truck side. I mean either way would work, but if he does it truck side, then if the truck ever had to be put back stock, it wouldn't work because it would be wired 9007 on the truck side.
