GMC 3500 dually wheel cylinders.
Old Jun 22, 2012 | 12:08 PM
ramitt360's Avatar
ramitt360
yeah I got a self bleeder and did that process since i didn't have anyone to help. The pedal is no longer squishy but needs to be adjusted
Old Jun 22, 2012 | 01:01 PM
Jigabop's Avatar
Jigabop
just spin the adjusters till the shoes make light contact with the drums...should be a very light drag when trying to spin the drum, but not enough to make it difficult to spin the drum. once you get it to that point, its adjusted. if it will just free spin with zero resistance, its not adjusted close enough.
Old Jun 22, 2012 | 01:55 PM
zman17's Avatar
zman17
Retired Moderator - RIP
Originally Posted by QuadCabLuv
Adjust rear brakes by applying emergncy brake while backing up.
LOL
Tighten the adjusters while spinning by hand with the wheel on, until it is locked up. This will center the shoes inside the drum. Then back off a few turns until there is a slight resistance. Repeat procedure on opposite side.
Old Jun 22, 2012 | 02:08 PM
charlie1935's Avatar
charlie1935
Originally Posted by zman17
LOL
That's we did it in the 1950's zman.
Old Jun 22, 2012 | 02:12 PM
zman17's Avatar
zman17
Well that's still how to do it.(On a Ram anyway) And backing up and hitting the brake pedal will help keep them adjusted.
Old Jun 22, 2012 | 04:56 PM
ramitt360's Avatar
ramitt360
Thanks for the replies
Old Jun 22, 2012 | 11:15 PM
RamusMaximus's Avatar
RamusMaximus
Your pedal shouldn't really feel squishy. Is it possible you let the fluid get low and sucked some air in? If you check your manual, there is a procedure to bleed the master cylinder, or the RWAL module, up front. It is not too hard. Then, try this - I read it on an Amazon.com review and it works good: Put some clear tubing that fits tight on your bleeder. Route the tube UP, above the wheel and put your bleed bottle on a chair. Pump the brakes (watch your fluid level). You should see solid fluid in the tube. When content, tighten the bleed screw. Start with the RR, then do the LR. If I were you, then I would do the RF, then the LF. Keep the cap on when you pump or it may spray fluid out the reservoir.
Old Jun 23, 2012 | 04:09 PM
ramitt360's Avatar
ramitt360
That's the exactly what I used Ramus, I see no air bubbles however i didn't bleed the front brakes. I didn't think i needed to but I will try it anyway.
